1 - 20 of 45 Posts
2.7 Trauma Surgeon
I filled the fuel tank up Sunday, and decided to throw some 2 stroke oil in the tank to make up for the poor lubricity of the ULSD fuel.
All I can say is, significant difference....definitely recommend doing it. Truck runs and idles smoother, and is noticeably quieter, now that the fuel system is properly lubricated. This is definitely good protection for the fuel systems on these trucks.
Make sure you use a 2-stroke oil that is twc-3 certified, and use 1oz per gallon of fuel (128:1 Ratio).
I was going to run it for a couple weeks before posting the results, but the results were pretty much instant. Ill post if there is any fuel mileage improvement.
2.7 Trauma Surgeon
Discussion Starter #4
Up from 15.3 mpg average, to 15.9 MPG....Im going to run another tank of fuel with the 2-stroke and see if the results stay the same since I drive varied amounts of city and highway. 477 miles this tank.
Truck is still running noticeably smoother, so this is worth it for the sake of the fuel system regardless of any mileage improvements, IMO.
Cost is close to just buying another gallon and a half of fuel at every fill up.
Shes going to the body shop for the next couple days, so it will be another week or so until I will be able to check the gas mileage again.
I've seen on other forums that some use the two-stroke oil and others use Marvel Mystery Oil and some use a combination of things that could include either of the previous mentioned or a product called Power Source (I think that is what it is called) Stuff like this can be subjective but if it works then why not. Do a google or similar search to see what other have done on other forums as well as this one which has many excellent postings on a variety of subjects and maybe on one like this subject. I know if anyone is running the new 6.7 I would be careful using anything that might clog the catalyst.
Much too young to focus,
does this affect the VP44? im on the second VP44 and the fuel pump went the firsr time around, i think its the low sulfur content in the ULSD that is doing the killing.
This is to help lubricate the VP.
I have been running it for over 35k miles and I love it. And for you stock guys, it adds a little smoke.
Also, I run the walmart house brand outboard 2 stroke in my truck. Its about $10/gal and lasts me about 3 fillups.
-Greg
should i drop the oil in first then fill her up? what if i ran a little on the lean or heavy side, i don't usually run below 1/4 tank so its always a variation in the gallons. any noticeable size effect when running lean or heavy on the mixture? I have to fill my truck up tomorrow so i'll be trying this out.
Power Wagon #1605
I run 10W30 in my fuel. I think im gonna stop at Wally World tonight and get some 2-Stroke oil and give her a shot
Funny how this keeps coming up.
Here are the results from the www.dieselplace.com where they tried several additives.
Be careful as you can see some things make the fuel worse.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
Bridal Veil Falls
Good info, but what do all the numbers mean?
Multi-purpose
HFRR 575,
61 micron improvement - Talks of the lubricity improvement of the fuel.
400:1 ratio - 400 parts fuel to 1 part additive.
8.32 oz/tank - figure a 35 gallon tank with the 400:1 ratio as listed above
$1.58/tank - cost of additive per tank
This help?
-Greg
Bridal Veil Falls
Got it...
I ran Wallyworld 2-stroke a couple of years ago and instantly noticed a quieter engine/injector pump. I ran that for about 6 months and liked it. Then I started blending WVO with my fuel. I now run about 5 gallons of WVO per fillup and notice no difference in performance. The only difference is the smell. Has a distinct smell of fried foods.
Senór Member
well, i think that imma try this stuff when i fill er up on thursday, can't hurt nothin, right?;D
and, if i can get ahold of a good supplier of WVO, i'd use that instead:tup:
Bridal Veil Falls
What is WVO?
Vegitable Oil?
1 - 20 of 45 Posts
