1 - 3 of 3 Posts
moparman505
How many times have we seen that on here? Well it started happening to me. Engine was running sweet then when I would put it in gear it would start missing and stumbling but would clear up once throttle was used.
Well here we go. Checked for vacuum leaks, looked inside throttle body for signs of oil, changed plugs, checked plug wires, and checked coil and fuel pressure. All was good but stumbling was getting worse! It had to be an injector problem.
It was! Like a dummy I haven't put any injector cleaner in since I put 408 in and the Accels have the multi hole pintals and will dirty up a lot easier than the stock ones. Put some cleaner in and after tank of fuel was run through she is now running fine again. Now why didn't I think of that sooner?
sound bite please! 408s :rck:
hey man? how did you get that 95 408 tuned? the obd1 is not vulnerable to tuning software. ?
1 - 3 of 3 Posts
