1 - 6 of 6 Posts
ok plain and simple engine light kicked on while my truck was idle outside my house ran it on my buddys scanner cylinder missfire cylinder #7 i have so much as opened the hood in 2 months so i know i didnt knock anything loss any ideas?
Translation:
" I haven't opened the hood in 2 months, so there's no chance that I messed anything up"
:thatfunny
Sorry, I couldn't resist. Anyways, time to do some tune-up maintenance. Spark plugs (gapped to spec), wires (route as per TSB http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm), distributor cap and rotor. Report back if problems persist.
here's my thong the the damn tune up is mabey got 30k on it i pulled the plug and wire plug looks good and the wires perfect i dont even feel the miss when i power brake it? lol i said i didnt touch anything cause thats always everyones first question " what did you touch"
It's hard to notice an intermittent misfire on one cylinder, especially an 8 cylinder. remove the distributor cap and check for any spark damage inside. I've gone one year with a tune up and the distributor needed to be replaced.
If you have a spark tester you can hook it up and confirm the misfire.
Registered MOPAR User
my 318 dak turned out to be a bad pcm, #6 went first then a month later the next cylinder went. First check would be to inspect the fuel injectors and spark system
Ya first things to check are spark and fuel. try swapping plugs, wires, and injectors to see if the misfire moves to a different cylinder then you know whats causing it. And if none of those are the cause, next would be to do a compression test. Hope you figure it out.
1 - 6 of 6 Posts
