I am throwing a code that states #7 misfire.
I have changed the plugs and it came back up same code.
I have changed the coil pack and once again same code.
Any ideas as to what the problem is???
What is left to trouble shoot?
Thanks for any advice.
Admin - David Mack
What did the plug look like? What did the connector to coil look like? Did you move the problem coil to a different cylinder to see if the error code follows? When was the last time you did a compression or leak-down test on the engine? Have you seen any moisture in the engines oil? Have you lost any coolant where you keep adding to the bottle but in a day or two, you need to add more again.
Admin - David Mack
The only other thing I can think of is a bad fuel injector.
One,
X2 on what Mack stated.
+ Hemi Addict +
Internal damage can cause a persistent misfire, with the Hemi most likely a broken valve spring, bent valve, or a problem with the valve seat that would hold the valve open......has there been any rough idle, noises, surging, etc?
A compression or leak-down test will confirm any issue causing compression to be affected....
