Good evening,
Have a 2000 Dodge Dakota 3.9 v6 with approximately 150,000 miles truck has been running great however one day it started to misfire at idle. Approximately two months ago complete tune up was completed plugs wires cap coil. Approximately 3,000 miles went by with no problems whatsoever. However one day the truck started to idle rough intermittently. However the intake manifold gasket had a slight leak replaced today same problem occurs. All fuel injectors read approximately 13 ohms. Truck finally showed a code and was cylinder four misfire. Removed injector in cylinder 4 to cylinder 6 to see if the misfire would follow the injector to cylinder 6. Truck runs the same at idle as it did, rough intermittently but will not trigger the check engine light to retrieve code. Highly doubt it is the fuel injector causing this problem. Any help would be greatly appreciated
