1 - 9 of 9 Posts
ok i have a ram 2500 04 ST with the stock manual mirrors. i was wondering if i bought tow mirrors power and heater for it, if there is already the wiring and stuff in there to plug it in to or if i would have to get manual tow mirrors. i know that there would be no switch to move the mirror with but hell, why not ask =p
You've been Hijacked
if nobody chimes in with an answer the best way to find out would be to pull one of your mirrors quickly and see if there is a harness in there
i was going to do that but its way to cold outside to do anything truck related.
Power Wagon #1605
Well just pull off the door panel and see if the harness is there. From what I have heard, some do and some dont.
Discussion Starter #5
i think ill go check now. its dark but i think ill live.
Discussion Starter #6
i dont see any wires. i just see a big friggen piece of foam crap behind the mirror inside the door. i stuck my finger in there and i felt what was like a hole maybe for somethign to clip in but no wires anywhere.
Power Wagon #1605
Then you are not prewired. This may be a better option if you want powered/heated, or just get OEM non powered.
www.tttmirror.com
Moe's sells them also.:D
locogk
you would have to get the dashboard switch and maybe you can get the wiring harness for them from the dealer i didnt have the harness for the cup holder light and i didnt have the plug under the dash for the electric brake controller so i had to hard wire both of them it just took more time and some thinking ( the thinking hurt ) but i got them both hooked up it is grat having the heated/ power mirrors it is worth a shot
locogk
oops spell check great
1 - 9 of 9 Posts
