1 - 14 of 14 Posts
Originating Member
"The reinterpretation of automobile and tire technology of the ultra-high performance partners Maybach and Fulda"
check out this car:
its definately .... different
Originating Member
Discussion Starter · #2 ·
the DC Press release:
The project Exelero - the legend lives
Stuttgart, May 18, 2005
Just imagine an automobile that combines the elegance and first-class quality of a high-end limousine with the powerful suppleness of a sports coupé. Create a vehicle in your mind’s eye which, with an unladen weight of over 2.66 tons and the dimensions of a small transporter, achieves a maximum speed of over 350 km/h. Conceive an ultra-high performance tire which not only copes with the aforementioned weight, the dimensions and the speed, but also makes the automobile safe, stable and comfortable. Such a vehicle and such tires do not exist? Now they do.
Always something special
For 99 years, Fulda has been making car tires. For most of this time, the company has advertised its products with special vehicles. Luxury buses, advertising vehicles with special bodies, high-speed buses for tire tests, a whole series of showtrucks, racing cars and - in the 1930s something quite special - streamlined car from the Maybach company which could conduct tire tests at speeds of over 200 km/h.
Unfortunately, not for too long, because the test car designed in 1938 and delivered in 1939 disappeared during the war years and never reappeared again.
66 years later: Fulda is introducing a new sophisticated high-tech tire to the market. For the most extreme dimension of this tire line, 315/25 ZR 23, licensed for speeds of more than 350 km/h, and that as a series tire, not a racing tire, what was needed was a high-speed vehicle but not a racing car. A few years ago, one the most exclusive German automobile makes was revived, why not organize a joint project together once again, just like in the old days?
Cooperating with Maybach
The contacts were made and thanks to René Staud, a world-class photographer of automobiles and an outstanding "networker" of DaimlerChrysler and Fulda Reifen, they were purposefully and effectively developed. Following several coordinating discussions with Leon Hustinx, Maybach’s manager, agreement was reached: Maybach would build a car for Fulda. Objective: to position the vehicle as an impressive ambassador for the new ultra-high performance tire generation Exelero. An indispensable helper in the boat with the project partners: two professors and four students from Pforzheim Polytechnic’s Dpartment of Transport Design. Together with the design professionals from DaimlerChrysler, under the direction of Professor Harald Leschke, the team went to work and after three-quarters of a year of promising design proposals, it was decided to realize the outline of the student Fredrik Burchhardt. He succeded in producing the most elegant symbiosis of design elements of former and present vehicle generations.
The model phase starts
Three model construction phases in the manufacture of a special vehicle are decisive in the development process:
  • the exterior design reference model (for the construction of the negative molds)
  • the interior reference model and
  • the chassis order with auxiliary frame.
Based on detailed and strict time schedules, all three phases were realized simultaneously. The well-known Italian vehicle study manufacturer Stola in Turin was commissioned by DaimlerChrysler to build the Exelero. The sports coupé was also now given its final project name: Maybach Exelero.
On 31 May 2005 everything was ready. All three phases were completed. The 1:1 model for the exterior had been tested in the wind tunnel many times, modified and adapted. The interior details were fixed: natural leather, neoprene, coated punched aluminum sheet as well as carbon fiber in glossy black and red are the main materials. And the technicians who worked on the vehicle had arranged, rebuilt and made ready for use all the functions and the parts needed for this. Dipl.-Ing. Jürgen Weissinger, the responsible project technician and development manager at Maybach, connected the battery, turned the ignition key and the car growled into life. The short burst of gas suggested record speeds.
The construction and test phase concluded with a outstanding success
Transforming a limousine, the basis for the Exelero is the Maybach 57, into a coupé is extremely demanding. Jürgen Weissinger and his team were astonished to find that, although the dimensions of the former SW 38 differed in the length (the Maybach 57 has a 290 millimeters longer wheelbase), in terms of breadth and height they were very similar. That simplified a whole series of structural measures.
When considering the engine alternatives, it soon became clear that the basic twelve-cylinder engine used in the Maybach limousines would not achieve the desired maximum speed of around 350 km/h despite the Biturbo turbo charger. Here, the Mercedes Car Group leapt into the breach. The engine specialists in Untertürkheim, the place where all basic engines are developed, provided energetic support for the project.
After several optimization of the Maybach type 12 engine, the cubic capacity was increased from 5.6 to 5.9 liters and the turbo charge optimized. The result was convincing: on the test bed almost 700 hp and at least 1,000 newton meters of torque were recorded, sufficient to achieve the targeted maximum speed of 350 km/h.
Before, during and after the aforementioned work, the individual evolutionary steps were supported by corresponding tests. Either on engine test beds in the plants or on test tracks like the high-speed oval in Nardo/Southern Italy or the test track in Cloppenburg.
The final test measurements at the end of April/beginning of May 2005, once again on the high speed Motodrom Nardo, then produced the well-earned success of lost of hard work: a top speed of 351,45 km/h - a world record for limousines – on standard tires.
And yet another world record: between the Fulda idea, the outstanding cooperation of all concerned and the delivery of the Maybach Exelero sports coupé, just 25 months passed.
Thanks to all cooperation partners
Yet again in Fulda Reifen’s company history, a cooperation has led to an exceptional final result: a top-class product like the Exelero ultra-high performance tire is matched by an exceptional vehicle, unmatched anywhere else in the world, the Maybach Exelero sports coupé.
The result can never be the product of just one individual, only within the framework of a partnership at the highest level and the uncompromising efforts of all concerned can such a project succeed. The Fulda project team under the direction of Bernd J. Hoffmann, Chairman of the Board of Management, would hereby like to thank everyone involved, particularly the responsible persons at
  • DaimlerChrysler/Maybach, Sindelfingen (design, Product Communication, engineering and engine construction)
  • Stola, Turin/Italy (prototype construction)
  • Pforzheim Polytechnic (Department of Transport Design), Pforzheim
  • René Staud and his company MEM Motor Event Marketing, Leonberg
  • Excentric/ATP-Felgen, Bremen"
Originating Member
I usually put DC Press releases in the Daimler-Chrysler Press Releases forum, but this thing is so far out, I thought you guys might like to view it here ....
We saw this a few months ago at a supercar forum I'm part of. It always reminds me of a batmobile...and that cowcatcher looks like it could do some serious damage!
Moparisticist
If ya really look and think about it the car looks like mazda rx8 from the front
I can see how you could get that, but this thing is really a totally different beast. Just way out there.
Haha, I would still pick the latest movie's Batmobile over any other, though.
Moparisticist
i do understand that the exelero is an AWESOME car but im just not the supercar type my idea of a wild car is a RELIENT that can BLOW THE DOORS off a suped up TOYOTA SUPRA
Hemi 4x4/Challenger T/A
Can you say "The Car"? Sure you can....
GrayMare said:
"The Car" was a souped up Monte Carlo! Movie had James Brolin in it!
Si...and that car was every bit as fugly as the Maybach.
The front looks really good, Steve. I like it better than the original.
1 - 14 of 14 Posts
