Hi,
I am planning on replacing my master cylinder in my 1984 B150 van. The pedal is slowly smooshing to the floor and occasionally the break light stays on and you have to smash it all the way down to make it reset. There is a drop in the booster pressure after turning the car off, so i think the booster is fine.
Any tips on replacing this? it has been a while since my last master cyl job. I assume there is a bleed order to which brakes get bled, correct? And I assume when disconnecting the brake lines from the master, you are essentially introducing are "way" up stream, so pushing that air bubble out is mandatory.
Would a quart of fluid do the trick for this job, once it cycles through?
This will be a one man job, btw;-)
thanks for any help
thanks for any help
