1 - 20 of 29 Posts
Well boys and girls,
I have successfully installed an overhead console into my 99 Durango SLT.
The process wasn't as hard as it may seem. For all those interested I will be taking pictures of the process and writing a step by step instructions on how to do it...the entire cost was around 110 dollars...50 for the overhead console and about 8in of the wiring harness, from the local junkyard, $40 for the ambient temp sensor from dodge, and $20 for 50ft of 18 gauge wire from Home Depot...I should have the pics and instrucs up later this week...if you have any questions PM me... :rck:
Keystoner
cool. congrats on your install
I so want to do this !!!!! I have seen the Over heads for sale on E-bay and would love the functionality this adds.
I can’t wait for your pix and the step by step on how to do It.!
If someone wanted to add a LCD to the Stock Overhead I still have one off the Shelby that is for sale. Would be a nice addition for anyone with little ones in the back or just a nice addition. It's availible in my sig.
Also, has anyone seen the smaller consoles that are to be used if you have a Sunroof installed?
thanks,
Russ
Russ,
There's no aftermarket "shortie" console for Durangos with a sunroof, at least not for '01 model years.
The installer just cuts and refabricates the existing console to make room for the sunroof.
Depending on the installer, there are a few ways this can be done. As an example, I lost the sun glass compartment when I had my moonroof installed. But the installer covered the console with the roof liner. Others have had different results.
Good luck.
T
99 Durango SLT 5.9L
Can you have a moon roof and rear A/C??
Keystoner
the rear ac lines run up your side pillar on passengers side. anything is possible
99 Durango SLT 5.9L
Rock, Do you have headers under all that pretty yellow plastic?? My headers have burnt just about every pice of plastic shielding under the hood...
Keystoner
headers is where I've stopped at.
talonbourne:
And they said it couldn't be done!
CONGRADULATIONS!
Now your sayin that it does the same things the stock overhead does, right?
Later
Ugg?
PS: Rock, my kit (from Toucan Ind) came with all metal, no plastic at all.
Discussion Starter #11
yes, it is a stock overhead console out of a wrecked 99 D... all functions,ranging from the DTE to Trip ODO works and the temp functions within 2 degrees of all the Bank Temp readings.
99 Durango SLT 5.9L
What about the trip and MPG how does all that plug in?
talonbourne , I sent you a pm.
Shawn
Discussion Starter #15
shawn,
thanks for the PM I will have all the steps and pics up on the how to do section by monday...have to wait for the digital camera...darn brother...but I will have everything up by monday...maybe sat at the earliest...
Discussion Starter #16
as for the Installing an OTIS/EVIC into a KJ, install...the jeep and the dodge instructions, plugs, and install are not the same...I first thought they were but after some tinkering I found that they are completely different...after some extreme frustration...this install took me about 2 hours to do, but 3 months of research and hearing it could not be done...but at last it can...just a little more patients... and I will have it online for everyone... thanks guys
Hey talonbourne:
Now you'll have to change your signature. :rolleyes:
Later
Ugg :cool:
Discussion Starter #18
well I finished the how to instructions and am just waiting the ok to get it onto the how to section of the tech section...
Very cool!
Discussion Starter #20
Well for now here are the instructions...enjoy
How to connect an Overhead Console version1.0
By: Talonbourne
Items you will need: 1 Overhead Console with trip computer and mounting plate
2 Wiring Harness (connector portion to the console)
3 Ambient Temp Sensor
4 Electrical Tape
5 One Terminal Ring (this is for the ground)
6 60 ft of wire (I used both 18g and 12g (silver and gold colored)
for a total of 60 ft)
7 Soldering Iron with lead wire
8 Wire strippers/cutters
9 Screw drivers both Phillips and Hex Shaped
10 Fuse Puller
11 One ¼ inch self tapping screw
12 Power Drill
13 Chalk
14 Exacto Knife
NOTE: First thing you need to do, before attempting the install is make sure your PCM
can communicate with the mini trip computer. This is done by asking your local
Mopar dealer to look up vehicle schematics. To my understanding as long as
you have either/or any of these functions you are golden… them being: Keyless
entry, fog lights, steering wheel controls.
Install Process: (tools needed in this section are patience, screw drivers, wire strippers)
Removal Section
1. Make sure your battery is disconnected.
2. Remove the A-pillar panel (driver side)
3. Remove the Door sill panel (driver side)
4. Remove the connecting panel between the door sill and A-pillar panels.
5. Remove the Light assembly, this is done by applying pressure to the front of the light assembly housing (portion facing the front window). Pull down till the housing is removed, don’t be scared to give it some force, for it will come out.
6. Remove the mounting plate, by removing the 2 screws that hold it into place, you will not need the plate for the overhead console, but keep the screws, for you will need them to connect the mounting plate for the overhead console.
7. cut the wires, which are 20g, about 4 inches up from the wiring harness connector (away from the plug side connected to the light assembly housing) the wires are Pink (is the power line for the lights, off the battery) , Yellow (power line for the lights, runs the lights for when the doors are open and when closed prior to arming the alarm) , and Black (is the Ground)
8. Strip the wires about a ¼ or ½ inches if this is your first time.
9. Optional Have a beer for you are about half way done.
10. Prepare the wiring harness that came with the overhead console by stripping all the wires about ¼ to ½ inches. The wires are 20g and are as followed:
Overhead Console Lights Section
Black (Ground for the lights)
Yellow (Power for the lights off of battery)
Pink (Power for the lights, when doors are open and prior to
setting the alarm)
Overhead Console Ambient Temp Section
Black/Light Blue (Sensor Ground)
Violet/Light Green (Ambient Temp Sensor Signal)
Overhead Console Mileage and Gas Consumption Section
Violet/Brown (+ for the CCD BUS)
White/Black (- for the CCD BUS)
NOTE: You must twist these wires for proper readings.
Overhead Console Power Section
Black/Tan (Ground for the Trip Computer)
Blue/White (Power for the Trip Computer)
(Tools needed in this section are patience, soldering iron and
lead wire, wire cutters, electrical tape, the 60 feet of wires, fuse
puller, power drill, and self tapping screw)
Soldering Section
NOTE: pre measure all wires to desired length prior to cutting and
stripping. After soldering make sure to use your electrical
tape and tape up the new connection(s).
11. Connect via soldering the existing light section wires, them
being Pink on Pink, Black on Black and Yellow on Yellow (the
pre-existing wires to the new wiring harness for the overhead
console). This will now give you proper light function in the
overhead console.
12. Under the Hood on the passengers side front between airbox
and radiator, you will see a plug, that plug is the connector for
the Ambient Temp Sensor. Follow it till it connects to the main branch of wires (about 8 inches) and cut. Prepare two 12 feet of 18g worth of wire (measured from the grill to passenger side door, up the A-pillar, to the wiring harness connections) Now I ran my wires this way for convenience, you can follow the wiring layout done by dodge, but that will take longer and the frustration level is much, much higher. Now solder one wire to the Black/Light Blue (Sensor Ground) and use a strip of tape on both ends to distinguish between the two sets of wires. Now solder the other wire Violet/Light Green (Am Temp Sensor Signal). Afterwards, run the newly connected wires to the wiring harness of the overhead console and solder them to the corresponding wires on the harness.
13. Measure two 12g worth of wires ( I used silver and gold colored wires to help distinguish between them) of the same length from the overhead console wiring harness across the headliner towards the driver side A-pillar, down the A-pillar to the diagnostic port (black 16 pin plug found under the steering wheel by the hood release lever). Now it is very important that you twist these wires, for you will get incorrect readings if you don’t. Once again soldered the wires and taped them at the wiring harness, I used the Silver wire and connected it to the White/black (- CCD BUS) wire and the Gold wire and connected it to the Violet/Brown (+ CCD BUS) wire. Afterwards twist the wires with a power drill (connect one end of the silver and gold wires to the drill and the other end fasten down or held in place by someone, just pull the trigger and watch them twist.) Run the wires to the diagnostic plug and this is where you will need to splice the number 3 and 11 pins aka the White/black and Violet/Brown. Cut and strip these wires and then solder them back together.
14. Measure two 18g worth of wires from the overhead console to
the fuse box (found on the drive side) and cut and strip. Solder and tape one end of the wire(s) to the Black/Tan (Ground for the Trip Computer) and the other wire to the Blue/White (Power for the Trip Computer). The wire that is now the new ground, connect the terminal ring to the other end, running the wire to the fuse box, you will see a screw on the top left side of the fuse box. This is a perfect place to mount the terminal ring, at that screw to create the ground. Now the other wire, which is now your new power wire, run it to the fuse box and place it in fuse number 11 (a 10a fuse). This is the consoles power fuse block location.
(Tools needed will be patience)
Testing Section
15. With the newly created Ambient Temp Sensor plug, connect the Ambient Temp Sensor to the plug and run it through the rubber barrier to the outside of the engine compartment (there is a cross shaped cut out which to run the sensor plug through on the passenger side of the D) Taking your self tapping screw, connect the Ambient Temp Sensor to the body next to the left as you face the D, of the cross shaped cut out. Connect the plug to the Ambient Temp Sensor if you unplugged it from the sensor to screw it into place.
16. Connect the newly wired wiring harness to the overhead console, place the console either on the dash or let it dangle for the moment.
17. Connect the battery
18. Turn the Key on
19. You should see the newly powered mini trip computer turn on and the lights turn on
20. Check to verify that the lights work, both manually turning each light on/off and checking to see if they operate with the doors open and the alarm being set.
21. Verify that the temp sensor is reading properly and that your mileage programs are working…ie DTE, AVE MPG, ECO, ET, TRIP ODO (the ECO should read zero when not in motion)
22. To Reset the mini trip computer, hold down both the Step button and the US/M button.
23. To Calibrate the Compass hold down US/M button followed by the Step button till you see the CAL on the temp and compass display screen. Release the buttons and in an area free of large amounts of metal, do three 360 and the CAL should disappear, which means your compass is now calibrated.
(Tools needed will still be patience, chalk, and screw driver, and
exacto knife)
Cutting and Connecting the Overhead Console
24. After verification of proper working order, turn off vehicle and disconnect the battery and overhead console.
25. Now with the Overhead Consoles mounting plate in hand, place it on the headliner with the two screw holes lined up with the two screw holes in the roof. Screw it temporarily in place.
26. Taking the chalk, draw an outline of the console
27. Remove the console from the headliner by the screws
28. Draw a new outline inside the old one ½ inch in, with the chalk
29. Cut out the headliner on the newly drawn line
30. Place the mounting plate under the headliner (this will take a few tries to get it in right) and secure it to the roof via the two screws
31. Connect the wiring harness to the overhead console and attach the overhead console to the mounting plate
32. Connect the A-pillar panel, door sill panel and the panel in between
33. Reconnect the battery
34. Start the D and drive away with your newly connect overhead console
1 - 20 of 29 Posts
