1 - 2 of 2 Posts
I traded my 05 magnum SE in about 2 weeks ago for an 06 RT AWD
I have experienced a prob with it already that I never had with the 05 SE
If I'm accelerating (Lite or hard ) and let off the gas abrubtly ( like when someone pulls out in front of you) I will feel a jerk and the car quits pulling I can press down on the gas and the tach gos up a little bit ( maybey 3,00 RPM) but no go
I can then come to a stop and then the car will go again.
Then after a short bit I get a Check engine light, Then after a bit the light goes off.
Sounds like a tranny issue, or maybe something in the AWD system that is having problems with the sudden power shift. Have the dealer scan it, if the light is coming on then the computer is saving a code that the dealer should be able to look up. Could be something as simple as a fluid level or computer flash.
1 - 2 of 2 Posts
