thought i would let you know i found my intermidtent radio static problem on my 2005 magnum sxt... here is what i learned, the antenna coax cable runs from the radio, thru the car, to a antenna amplifier mounted in the right upper corner of the rear door under the trim panel, then the antenna amplifier is plugged into the antenna in the rear door glass.. it turns out the plug-in on the antenna coax cable for plugging it into the antenna amplifer was bad and making and breaking contact.. what a search since it wouldn't act up all the time.... hope someone else benifits from my experence..
