1 - 3 of 3 Posts
I got a set of comp cam guideplates for the magnum but the alignment sucks. Not toe’d In or out just not centered. Some are centered and some are shifted off center.what guide plates are you guys running? I might just put these on the mill and elongate the hole to make them adjustable. I will snap some pics later.
Discussion Starter #2
Here are the pics. Pics are on left side head as sitting in the driver seat. #1 is ok 3,5 and 7 are jacked up. See pics. 3 and 7 are kicked toward the front and 5 is toward the rear.
yah your right! that's no good.. call them about it.
I had other problems with comp stuff. my first timing chain was bad. although I have no complaints with the cam i'm running.
1 - 3 of 3 Posts
