1 - 2 of 2 Posts
Well my 2nd Intake manifold gasket went out...looks like i will be going to lucky number 3...The first 2 times it was done at the dealer since it was under warranty..first at like 20-30k then at 50-60k, and now at 84k it needs another..This time i will be doing the work myself, and buying a Good gasket, not the cheap mopar ones. While my Intake and throttle body is off, i will also be porting and polishing them, so i should see a little better power increase..i'll let you all know how it goes.
pakrat
Are you talking about the intake plenum plate gasket? or the intake to head gaskets going out? Hughes engines inc sells a machined alluminum plenum plate that is much better than the stock stamped steel plate. Check them out.
1 - 2 of 2 Posts
