this from
http://suicidedoors.com
AIR MANAGEMENT KIT # 4 $1099.99
· TWO VIAIR 450 COMPRESSORS
· TWO 5-GALLON 8-PORT AIR TANK
· 4 GC 3/8" VALVES 250 PSI (DUMPS)
· 4 GC 1/2" VALVES 250 PSI (FILLS)
· 10 SWITCH BOX "ANY COLOR"
· PRESSURE SWITCH
· RELAY FOR COMPRESSOR
· 2 DUAL NEEDLE 200PSI GAUGES
· 1 SINGLE NEEDLE 200 PSI GAUGE
· 50' OF 1/2" DOT AIRLINE
· 50' OF 1/4" DOT AIRLINE
· 4 AIRLIFT GEN 2 BAGS 180 PSI
Keep in mind you will still need about $200 in fittings
then what to do to your rear end ie 2link or 4 link.
then for the front aftermartet arms like byc arms ($300 for 3g rams)
But in the end you still only spend a little more then art and you have a whole lot more for your money just like nhram said..
It is in no way cheap to bag your truck so keep this in mind in your desecion . cause you can do a mcgauphss 4.5/7 for less then $600 ..
