1 - 2 of 2 Posts
I have an 06 Laramie with 5.7 hemi it's idling at 3 to 400 but it runs great I cleaned the throttle body no change then I replaced the throttle body and still id8at 3 to 400 any ideas. Thanks
a low idle believe it or not is a good sign. low is usually easy to fix. high idles can be more complicated with an added complication of intake manifold leaks.
for my low idle I just memory dump the computer. fixed itself. sometimes moisture can imitate a failing sensor. free and cheap tests first!
by the way your in the wrong forum
1 - 2 of 2 Posts
