'99 Durango with 5.9, about two years ago I had a problem with very low idle and stalling. A new IAC fixed it good as new. Now lately as the weather has turned cooler I have idle problems, but only on a cold startup. Right after the motor fires the rpms only ramp up to about 800 rpm, then fall down to 400 rpm, almost stalls, ramps up to only 800 rpm, then falls again. Usually it will stall unless I give it a little gas to stabilize it. Once it stabilizes it only idles at 600 - 700 rpm. It does seem to idle lower than normal when warm (600 rpm), but it does idle. I'm guessing it is the IAC again, but the last time I had a problem it would not idle at all, now this time it seems that it is halfway trying to work. Once in a while it starts almost like normal, with the motor ramping up to about 1100 - 1200 rpm right after firing then settling down to about 800 rpm. It runs great otherwise, accelerates great, even when cold.
I have just changed the intake & plenum gaskets, but this problem started before I took the intake off. I took off the IAC and cleaned it, I also energized it while it was off and the piston did move, but cleaning it did not improve the situation. It's definitely acting like the IAC is not opening enough, I took off the hose to the PVC valve and the idle immediately picked up 200 - 300 rpm with the extra air leakage into the intake. I'm not getting any fault codes, so here's my order of planned parts changes to see if I can cure it:
IAC
MAP
plugs & wires
O2 sensors
Coolant temp sensor
TPS
PCM
Let me know if you have seen an IAC act like this, and let me know what you think of my order of parts changes. Thanks!
IAC
MAP
plugs & wires
O2 sensors
Coolant temp sensor
TPS
PCM
