Well, I think I finally dammaged something on the 2005 Ram 3500.
Last week I was hammering the truck pretty good, and when I let off the throttle, I heard a loud "POP" noise. I assumed it was just the blow-off valve?
After this happened, it seemed like I was hearing even more wistling than normal from the turbo?
Since then I have noticed the truck smoked a bit more than normal, and my EGTs were hotter than normal, then Today I hooked up the trailer, and my EGTs were way too hot!. I noticed that my max boost was only around 11psi. I tried to see if I could get more boost, but about 14psi was about it?
I know the truck could hit over 25psi easy before this happened.
I think I am loosing boost somewhere, but I could not see anything obvious.
Could I have dammaged the blow-off valve? and how would I check it?
