1 - 3 of 3 Posts
My hemi5.7ltd2005 has nor more highbeam(indicator lamp for high beam is working) but both high beam lamps keeping dark... I couldn´t find any fuse/relay.
I would be very thankful for any help(no of fuse or relay) because i think both high beams couldn´t be defective at asame time, it must fuse or relay
Robert from germany
Discussion Starter · #2 ·
not anyone experienced that problem, low beam is working on high beam just the blue indicator light , the front high beam bulbs keep dark
It is not impossible for both bulbs to burn out... Just very unlikely... Pull the bulbs and inspect. Put a meter across them if unsure.
If the fuses are good - check for voltage at the bulbs. Swap the relay.
Still broke? Dealership time - it may be the computer. (Yes, *everything* goes through the computer...)
1 - 3 of 3 Posts
