HEY--i do know that this is one of the common problems with these durangos---mine has 104,000 miles on it.It was losing 2-3 quarts in between 3000 mile oil changes and the water was also going somewere? after some reading i came to the conclusion that it was the intake plenium gasket which seems to be a common problem with them sucking inward and causing the leak within the motor.--ok so i go to the local dealership and tell them to replace it and they do for about $550,with a metal type one now that is suppossed to not fail and they also say that the old one was bad and leaking.i drive it until the next oil change after 3000 miles and check it before i change it---well it is at least 2 quarts low ,because it barely shows on the dipstick and the water is low again also---i take it back and they claim that they cant find anything and put dye in it and tell me to drive it for 1000 miles and bring it back--i do without thinking to check it,they call me back and say that it must be good that they see nothing and that it has not leaked down any---i then go home and change the oil and after about 1000 miles i check it and i am close to a quart low already-----now my question is,does anyone know what else it could be---because i get the feeling that the gasket they changed did not seal for some reason and they are giving me the run around to try and keep from having to replace it again at there lose---any help would be greatly appreciated or any advice on if i am right and what i should do about that-----THANKS :VHOT:
