1 - 20 of 22 Posts
I have a 1999 1500 with the 5.9....I have a K&N Gen II Intake, Airraid tbs, Mopar performance heads, Jba shorty headers, High flow cat, Flowmaster 40 series and a hypertech power programmer. Am I better off getting a cam, throttle body, or ignition system of some kind. I can't afford to do all at once but would like any suggestions. :D
I got this from a guy at comp cams.....
INTAKE MASTER 3303B
EXHAUST MASTER 3307B
ENGINE CRS XR265R-14
GRIND NUMBER CRS XR265R-14
INT EXH
HYDRAULIC Y/N YES DUR @.050 216 224
INTAKE EXHAUST LOBE LIFT .3170 .3170
VALVE ADJUSTMENT HYD HYD ROCKER RATIO .00 .00
MAX GROSS VALVE LIFT .506 .506
DUR @ .006 TAPPET LIFT 265 273 LOBE SEPARATI 114.0
ADVANCE 4
VALVE TIMING OPEN CLOSE
.006 INT 23 62
EXH 75 18
THESE SPECS ARE FOR CAM(S) INSTALLED
110.0 INTAKE CENTERLINE
My problem is I know nothing about cams and this is greek to me.
Ram Racer
As soon as you get into changing a cam, expect to change a lot of parts with it for it to work right. Parts have to work together and putting in a mid level cam like that one means a lot of new parts to compliment it. Otherwise could hurt performance.
Minimum
Need to add 525 lift springs, retainers probably good idea to get some guide plates and treated pushrods. If hi mileage, lifters as well.
52tb, M1/2bbl intake manifold, 2800stall torque convertor and probably need gears depending on what you have (3.90 min/4.10 better). Last thing is your tune, need an sct tuner to get run a decent cam/m1 combo.
Ditch the tb spacer, not helping at all.
Also, be sure to check compression across all cylinders before thinking about serious internal upgrades
Platinum 2K R/T
Ditch the throttle body spacer and throw on a 52mm TB (Fastman or other). It's one of the better bang for the buck mods you can do and you don't have to tear apart the engine. If you decide to go with a cam, I'd get a BG custom tune to make sure you get maximum benefit from your mods. http://www.bgperformancepcm.com/
I R SMRAT.
:thatfunny
Go for a 52mm TB, then M1 intake, 1.7 roller rockers, ignition, and then a SCT tuner by Hemifever. Those things added to your current list (minus the TB spacer) should put a nice wide smile on your face....until you see the bill for new rear tires. ;)
Ram Racer
:thatfunny x2
Add in tranny upgrades if you do upgrade the engine internals, wont last long ;)
Discussion Starter #9
Thank you for the help. I just had the tranny rebuilt last July at 165,000 miles. I was told when they did the rebuild it would handle up to 450hp at the fly wheel. Is there a shift kit anyone recommends?
What heads do you have. I would not go with the M1 unless you have a stroker. Go with the Hughes intake. Intake has to come off to do the cam, might as well kill two birds with one stone. The cam you listed comp 20-746-9 is what I ordered. I have the M1 and comp 20-744-9. I got a Airgap manifold and I will post pictures when it's done. Pretty much like a hughes but the throttle body adapter is blended and welded on the manifold to make it one piece. Also it will be dynoed again.
Discussion Starter #11
I have the MP heads part#P5007145. They came fully loaded so all you had to do is mount them to the block. They are cast iron so i am not sure if you can get these style anymore. They may only come in aluminum.
I don't have a stroker yet.....kinda need more $$$$$
What is the difference in the two cams? I would be really interested to see your results when you are done. If you don't mind sharing.
I R SMRAT.
Not to derail the thread, but any reason why you wouldn't recommend the M1 to a non-stroked 5.2/5.9 (5.9 especially)? I have seen many mixed reviews about it. Some say you loose low end, others say you don't. I always like to get another point of view.
Discussion Starter #13
That is a good point. Is it something that is going to hurt performance? Or if you add a 52mm throttle body would a M1 be a good compliment without losing your low end torque? (with mods already done to my truck)
the i didn't loose any lowend usually comes from dakota guys, the much heavier ram usually you will feel a loss unless you have a higher stall converter to make up for it. if you break into your engine and put a cam and heads you will want gears and converter.
You have the R/T heads those are good. Difference between the cams is duration and lift. If you search my posts I already dynoed it once. Don't buy the M1.
The torque peak comes in at 3900 RPM. Way to high for a heavy truck. With a stroker engine it will make up for the losses caused by the intake. Get the hughes intake it's less money than buying the Mopar intake and installation kit.
Discussion Starter #17
I just looked at your dyno results....not bad for the mods. I am probably going to do the cam and intake first then in a month or less get the tb. It will be alittle while before I can afford the tune and Dyno. Thanks again.
Ram Racer
Small cam, the m1 will hurt trq in a Ram, with a good sized cam though it is needed IMHO. Gears and stall are a must with cam and m1
You made [email protected]; [email protected]?
With all the mods in your sig?
Was that a mustangdyno or dynojet?
I'm not sure, it was on two dynos. All the mods were done. The numbers aren't impressive. Alot of power was lost because of auto trans, transfer case, 4.56 gears, and 35 inch tires. I also passed smog test with that cam no problems. Here is were it was dynoed www.dcperformance.com
Ram Racer
Sorry to jack the thread but
How much those 35s hanging out?
That 224x dynojet you were on has a max roller width of 81". I couldnt do pulls with my slicks on same dyno cause they hang out a bit (4.5"bs w/12.5" slicks) and would of rubbed. Sure your tires werent rubbing on the drum stationary side plates?
1 - 20 of 22 Posts
