1 - 7 of 7 Posts
How do you know if your truck has Limited Slip??
I have 2002 Ram 1500 with a 5.9l Laramie edition
Thanks
Ok thats what I figured
but why if I spin the truck on grass or wet pavement most times only one wheel will spin. I know it is limited slip but should both wheels spin on a slippery surface
Been HEMIphied
There should be a label in the glove box. See if it has the following listing:
DSA, which would indicate Axle - Anti-Spin Differential.
Being that you have an 02 there should be a label on the rear axle right behind the passenger side rear tire, should say ratio and either (open or anti)
1 - 7 of 7 Posts
