1 - 7 of 7 Posts
HEMI way or no way
ok i know most of you guys don't replace the lifters with a cam swap. i have always read that it is wise to install NEW lifters with a new cam. i am considering this, since i have 32000 miles anyway.
what do you guys think? replacing the lifters costs 200 bucks for parts.....and i dont necesarily want to go through that if i dont have to....
Inertia ROCKS!!!!
Well if your lifters fail after the cam install then I say YES you should have installed new lifters. Now if in fact they last a good long time after the cam swap, then my opinion is no....does that help any?
being as most cams now and days (last 15 yrs or so) are roller style with roller lifters its really un-necessary to change the lifters unless you really want to..........roller cams have less valvetrain wear due to the ramp design and the roller tips,meaning they can be re-used more often than you would think.
The old phrase of changing lifters with cams was more directed towards flat tappet cams where no rollers are used.
Valdez Racing Team
...and at 32k miles...thats hardly any wear at all...
Finally a 5 speed
Yeah the old cams and lifters wore together over time. I would not think that the hydraulic roller lifters in our truck have worn much so far.
MrDestinE
Let us not forget the Roller cam is made of Billet Material as well and is much stronger than say a flat tappet camshaft where cam break-in is very important and the lifters are matched to a particular lobe after break-in. Roller Cams do not require same break-in and changing the lifters are not necessary. It might be advisable if you wanted a lifter that allowed for a higher RPM but I have not seen to where the Comp Lifters rev any higher. ( or that it matters due to our rev limiters anyway ).
TJ
1 - 7 of 7 Posts
