1 - 7 of 7 Posts
i have a 04 ext. cab sxt v6 dakota that i installed a 3" fabtech suspension lift on the front and then a 3"body lift... i used the stock 16" rims and have 315/70/16 on it.. the problem im having is when i turn to the right, the end of the upper control arm rubs on the inside of the tire.. Do i need to put spacers on my rims?? any help is appericated. thanks
I put a 3" Rancho and my 305/70/16 on the stock wheels were rubbing all the time. The shop had to put 1/4" spacers on it right away. You have a slightly wider tire, but if you are only rubbing on the hard turn a 1/4" should do the trick. A 1/2" would require longer studs.
Fabtech has a lift for 03/04? where did you find? i can not find a lift for my 03 anywhere. How much did it cost?
How is it i have heard mix reviews about fabtech.
1 - 7 of 7 Posts
