Yeah that's what you need to do...... many garage heights and door heights are different...... mine is particularly low for some reason, my stock 4x4 barely goes into it.jayincali said:You can always take a tape measure and measure the lowest point in your garage, then subtract the hight of your truck. That will tell you how much higher you can go.
Ok, I'll be the first to admit, I'm not very good with suspension work, but how would you only gain 2-3"?Chauncy said:6" lift and 35's
you'll only gain about 2-3" of actually lift, maybe 5
anyone?Shamrock said:Ok, I'll be the first to admit, I'm not very good with suspension work, but how would you only gain 2-3"?
The 35's, if they have a true diameter of 35" would give you 1". So the lift would only come out to around 2 inches? Is it not rated correctly or what?
