1 - 2 of 2 Posts
05 Ram 5.7hemi. Water pump was leaking at mating surface behind themostat housing. Replaced water pump with new one. Torqued everything back to 18ft/lbs. still leaking in same place! Any recommendations?
What was the fix? I currently have a leak and thought it was the water pump, turns out its the timing chain cover that the water pump mounts on is leaking.
1 - 2 of 2 Posts
