I have a 2003 ram 2500 on which I replaced the power steering pump and now the pressure hose continues to leak at the pump fitting. Replaced the hose and o rings leak is still there, the flare end seems to be a loose fit in the pump fitting is there a larger diameter .flare end for this? Have tried two different hoses from different vendor's bit the problem persists.
