1 - 10 of 10 Posts
I hope someone could give some advice,I have a noisy leaf spring I have
raised the truck and sprayed in between the leafs but the noise is still there.
Is their a problem with the leaf?
Is their something else I could do or correct?
:help:
Do It In A Van
Your leaf spring bushings perhaps? Don't spray those with WD-40...use silicone spray.
there is also a tsb on leaf spring noise.it consist of replacing spring pads and lube it is easy to do and not expensive i did mine for $10
Theres a TSB on this at Alldata.com...
Do you have a direct link for the TSB?
FREEBIE!!! Thanks QCRam
Discussion Starter · #10 ·
Hey thanks to all who replied.
Sorry I did not answer sooner but I just got my truck back from the dealer today and they repaired my leaf springs per the TSB. And what a difference the new isolators made,quiet. The dealer did it due to my warranty covered it all.
Thanks again :gr_patrio
1 - 10 of 10 Posts
