http://www.dodgetalk.com/forums/showthread.php?t=297085
Here's a little bit of an update on my cylinder heads. I thought the cylinder heads would be like the HO cams; by the time I got home the computer would have them figured out. At first I was little disappointed in the HO cams until they had been in the truck awhile; I’m finding the heads to be the same. I knew the true performance wouldn’t come to life until I had a good intake and exhaust system but I was hoping for a little more umff. And just like the HO cams the more time the heads spent in the truck the better they run. For the first week, I notice my wideband was running rich. I was sure that’s where my missing ponies were going; right out the tailpipe. I can’t give you any type of fuel mileage numbers right now because I love my “auto start” with my Clifford system; nothing kills your mileage like an engine that idling with the A/C on. I’ll get good fuel numbers this weekend when I drive to Houston for the Aeros and Auto 2010. I have noticed that my water temperature is down. I’m seeing the needle is lower buy three to five widths. My guess is the temperature is down about 25 to 30-degrees.
This week, I’m seeing the wideband lean-out a little and the performance going to the tires instead of the tailpipe. I should have learned with the HO cams that it’s not the miles but the number of on-and-off cycles with the engine. I was thinking my next mod would need to be something to help the engine utilize the heads to their best but now I’m thinking I’ll replace my rear bent rims. With good rims, I can run the rpm’s up into the fun level. I bumped the “fun petal” today and she felt great even with the 90-degree temp and high moisture levels. I believe I’m going to go by the tire shop and see if I can get some replacement rims and a set of tires so I can do a burn-out video. I think if I get the burn-out out of my system, I’ll be able drive save on your city streets.
I’ll update again when I have some good numbers.
