I've been having problems with my 2010 Dodge Journey RT. The other day I went for a drive and put my vehicle in park, went to turn the vehicle off. I turned the key to off n took the key out but the vehicle was still running so I put the key back in, an tried turning it off an removing the key but it wouldn't shut off so I left it for a bit and it turned itself off. Then on the dash it said "Damage Key" and "key in ignition". I tried starting it but it was completely dead. The headlights work but nothing turned on, on the inside of the vehicle. I had to get my vehicle towed home. So this morning I went outside and the vehicle started up but the same problem happened, took the key out but the vehicle wouldn't turn off. So I had to disconnect the negative battery cable to turn it off. Has anybody else have this problem I'm not exactly sure on what to do ???
