you definatly have a wireing problem. you have constant power applyed to the coil someplace. because the coil is getting continuios voltage and having current flowing all the time and overheating the coil. im not sure if the hemi's are ground switched or power switched. (i would assume power) you need to find the source, i would figure out what wire it is off of the PCM, disconnect that plug and check there for voltage. and see if you can get it to change with the key on/off. and if you get a constant voltage on that wire (with it disconnected form the PCM) you will know there is a problem in the wireing someplace if there is nothing connect it back to the PCM, and test at the connector. (for the coil) and if you have countinious voltage there your issue will be in the PCM. because if i remember right the power for the coils comes straigt off the PCM to the coils. (nothing in between) so that is what i would check.
