I just thought that subject would get some attention...
When I bought my Ram a couple of years ago it had some rust starting on the Flowmaster tips. I figure they are probably chromed. I don't want to have them replaced ($), and the chrome doesn't really match the wheels anyway. So I thought I would sand off the rust and paint them aluminum like the wheels. I picked up high-temp engine primer and paint from Autozone and I was planning on using that this weekend. However, I am worried about the tips still being to hot for the high-temp paint. I'm sure it will look good when it is done, but I am not sure of the feasability.
Has anyone ever tried this, or knows if it will work or not? :huh:
Hotty Toddy Gosh Almighty
They won't even be close reaching the max temp of the paint. That pain is rated for 1000+ degrees. The exhaust leaving the engine right at the headers will be quite hot, but at the pipe tips you will be fine.
The paint is rated for 500 degrees, does anyone know how hot the tips get?
Put a couple drops of vegetable oil on the tips while they are hot. Unless the oil scorches and turns black the pipes are less than 500 degrees.
well that is brilliant, i will try that
