well, i've been milkin' the guys on the 2nd gen forums for awhile, but after all that, i bought an 03. whatcha gonna do? but,....it was built 07/02, titled as an 03, and a parts guy told me the rad hose was for an 04
anyway, the thing has two issues for now.
1) the batteries were cranking too slow and were vulnerable, if you didn't run it very long, to not being able to start it a second time. so, i stuck two 1000cca batts in it and it cranks sweet, but the voltage stays down below 12 for a minute after it's started,...then it kicks back up to 14. gas motors with a single battery bring it up right away, so what gives? normal?
2) also, as i was swapping out the batteries, i noticed the top hose was blown (i hope not for long). so, the local parts stores (4 so far) don't carry it. one that they gave me had the same diameter on each end, but mine needs the radiator end to be about 1/4" larger. one guy said the 04 shows those dimensions??
thanks for the help guys, kevin
