Absolutely. The PCM requires various inputs from engine sensors so the engine can run properly. One of these sensors is the coolant sensor. If the engine never acheives proper operating temperature, the PCM won't be able to adjust things like ignition timing and fuel/air properly.
Make sure you buy the proper thermostat...probably a 195 deg. is OEM.
