After getting my 2000 sohc neon about 2 years ago one of the only problems i had was a intermittent lower than norm idle that would happen at stop lights mostly, i could tell it was lower than norm by the feel and the way everything would shake and rattle. I don't think the rpm gauge was accurate enough to read the slight difference, which is why maybe there was never a check engine light. I kept thinking it was the idle air motor, i cleaned it over and over with no luck. Recently i noticed oil on back of the motor, i traced it down in part at least to a cam position sensor that was leaking oil right into the electric plug and it was coming out of the harness. Just on a whim i replaced it and the intermittent low idle problem has disappeared. When a mechanic friend of mine looked at the back of the motor he had said your head gasket is leaking oil as well. I cleaned off the area and i am waiting to see if oil builds back up, i thought they had the head gasket problem fixed on these 2nd gen neons. My car only has 40,000 miles i would like to think that the head gasket would not fail so soon.
2nd Gen neons arent known for headgasket problems... He could just be seeing the oil on the block from the leaky cam sensor. Do a compression test if you're worried, gauges are cheap and you can pick them up at just about any autoparts store. Takes half an hour tops.
