You can get the folding rear seats and power heated seats out of an Intrepid ES or 300M/LHS, the plug for the power will be under the carpet in front, so thats plug and play...you'll have to run your own power for the heated part. They are direct bolt in. Center console and shifter can come out of any Intrepid with one, 98-04. You'll need a shifter cable and steering column trim also.
I've been searching wildly for pictures and have found random interior shots.
I notice on the end of the center console there are vents. Is it safe to assume, that there is some duct running from front to rear in the console? You mention the shift cable and steering trim, so I'm assuming this is for the autostick conversion? I plan on converting to autostick, but I may as well do it now. My main concern with the rear seats is if there is a latch bracket? I would hate to get the reat seats and discover I need a bracket for the seats to latch in the up position. :YO:
For the trip system--called EVIC since your an 04, you need the overhead unit, and the harness...you just plug it right into the fuse panel, there is a socket for it. You will have to trim your headliner to get it to fit.
Since this is not part of the dash, I'm assuming that I could hold off on this until after changing the dash area, since the wiring just needs to be connected in the headliner?
Climate control -- requires removal of dash, and replacement of dash harness with one from a vehicle that had it...yours would need to come from an 02-04 LHS, Intrepid, Concorde, or 300M that had ATC. You also need the head unit, blower control module, and blower box harness.
By head unit, do you mean the dash component? So I only need the 3 parts for this mod?
You might as well add autostick while you are doing all that stuff...you'd need an autostick cluster, shifter, and bezel, and then run a couple wires for the shift sensor.
It seems, overall, that I do not that many additional parts. The breakdown seems to be:
Climate: 3 parts (dash component, blower control module and blower box harness)
EVIC: 2 parts (Unit and harness)
Autostick: 5 parts (Autostick cluster (dash gauge to remove the P R N D from the cluster?), shifter, bezel (center console piece with P N R D on it?), steering trim (due to remove of column shifter?), shifter cable)
Rear seats: 2 parts (seat backs and seat bottoms)
Power heated front seats: 4 parts (Each seat, harness and center console) So since my driver seat is already powered, I would only have to create my own power for the heat portion? What about the passenger side, since it is currently not powered?
Since these mods have been done before, are there any step-by-steps or guides for assistance? Also it seems that I just need to find all the parts from a 02-04 LHS/300M (since I prefer the 300M seats). Lastly, any idea what the colors the seats were avaliable in? Currently I have dark trim with charcoal seats. It charcoal the same as black or gray for these cars?
Thanks.
Daytrep, I noticed in a previous post of yours, you mentioned knowing someone that keep parts on hand with some of these mods. Could you help with some places that carry parts? I don't seem to be having any luck around San Antonio.
