DodgeTalk Expert
Rear spoilers are one of the most popular auto accessories available on the aftermarket. From mild to wild, a rear spoiler can change the entire look of any vehicle. We have 4 exclusive options from designed for Dodge Avenger 2011-2014 from different manufacturers, which you might find interesting.
Remin® - Factory Style Rear Spoiler has high-performance OEM style, made from automotive-grade ABS plastic, installs easily with with screws and gaskets. This spoiler gives the sleek, more high ended appearance to your vehicle. If you like the factory look and like to dress up your car without getting carried away, then a factory rear spoiler is probably for you.
Pure® - Factory Style Rear Spoiler is made of high quality material such as Fiberglass. The fiberglass is precision formed and lightweight. It's secured with screws and gaskets. The spoiler comes with everything necessary for a hassle free installation, including detailed instructions. It will enhance your car's shape and improve its silhouette with sharper lines.
JKS® - Factory Style Rear Spoiler helps to give your car the same look as the high-performance models. It improves aerodynamics, has factory high-performance style, made from ABS plastic and installs easily with screws and gaskets.
T5i® - Factory Style Rear Spoiler will perfectly complement your car's fine lines, and its distinctive shape will set your car apart from lesser models. It delivers a sporty image that is easy to be recognized. Made from Fiberglass, installs easily with screws and gaskets, backed by a lifetime warranty.
Check prices for your model and see other details here: 2014 Dodge Avenger Spoilers at CARiD.com
As you can see, all 4 spoilers are made to meet any aesthetic needs. And which one would you prefer?
