rock_hauler
How can you tell if the plastic intercooler is leaking, what are some signs and what to look for? Where is the usual place for these to start leaking? Sometimes I shut the truck off and I can hear a hissing sound coming from the passenger front side. Mine has the plastic tank.
2005 Ram 3500 Dually 6sp
If your intercooler has broken a seal, you won't have any power, as the turbo is not able to build any boost. My guess is that you hear the A/C compressor. It's especially noticable if you leave the A/C on when you turn the truck off.
I agree w/Hemi Freak..........could be the a/c or defroster causing the noises.
If you still feel it's a possible intercooler leak, get a spray bottle and mix up a soapy solution (dishwashing detergent & water) and spray around the tanks (sides) of the intercooler, then check for bubbles.
Greg
If its not the A/C, then it could be the turbo spooling down. After you shut down, the momentum will keep the impellers spinning for a couple extra seconds as the pressure drops.
