Ok guys since the Indy Intake is getting such a bad rep what about building off the stock manifold or customize another manifold to fit into the neon. What are the options here I wonder?
The main thing I would think that would make it better is to cut off the TB plenum and weld it back on going straight in and eliminate the 90* turn. Since Im already welding and cutting on it I may as well cut it apart and add some new longer runners while I polish and grind out all the material I can. What do you all think? Best Idea or what? Im sure that I could add an inch or so to the runners if it would make a diff. If not Id just grind away most of the insides. I cant seem to find any good pics of a P&P project on an intake mani.
Any Ideas guys?
Any Ideas guys?
