i am an idiot. i pulled the gauges so i could get rid of the turqoise tint behind them. now, when i out the needles back none of them read right, and the speedo isnt working at all. how do i put the needles on so they are in the right place or did i just screw myself?
you should have marked them befor hand....
Hmmmmm
Well your going to have to start it up and do your best to remember where the needles are at idle....but im sure you figured that out already, sorry to say I did it and I would have done the same thing if the directions did say to take a piece of paper and note where there at at idle, hope all works out for you, only problem I can see is if you don't remember your gas, good luck
for the gas gauge just go fill up the tank and set the needle to where it usually sits, probably a tad past full. tach and speedo at 0. set everything else from memory.
