Directly on the fuel rail on the passenger side of the motor. Just unscrew the cap, remove the shrader valve inside, and then screw your fuel line on and you are set!!
hahaha, hey matt, i think you should quote that, make it big and bold and put it in your signature!! you are tha man!!....just dont quote ME on that. lolcretamk said:hemi450, just in case you didnt know, you are the man. thanks
If the fuel line supplied in the nitrous kit doesnt fit, then you will need to either buy a new braided line with the right fitting on the end, or get an adapter like you said. I would probably buy a new braided line though...1 less leak to worry about.cretamk said:ok so that was the hose that i was looking at. i took the plastic cap off and the inside does look similar to a tire valve. The problem is that the hose for the fuel line to the nos wouldnt fit the fuel port. Do I need to buy an adapter? And on the inside of the port i see a pin. Not anything that can be unscrewed with a small screwdriver.
You are looking at the wrong one then. Here is a pic of mine just to show you what we are talking about. It is on the passenger side just to the right of the 2nd coil pack to the front. I have a silver cap on mine, but yours should be just a black plastic cap...cretamk said:The valve that i found has threads on the inside of the valve. The nos line connection needs to hook up to something with threads on the outside. Is the valve you guys used have threads on the inside as well? I just want to make sure i am looking at the right one. Thanks again
No problem.cretamk said:i was looking at the wrong one. thank you so much. i really appreciate it.
LOL :rck:HEMI450HP said:No problem.
BTW...Thats and AWESOME sig you got there...HAHAHA
click on "my gallery" at the top and then click on "my stuff" and it'll pop down a menu and say "my gallery" click on that and then go to upload... upload some pics and wait a coupla hours for them to show up cause dodgetalk has to approve themcretamk said:how do i make a gallery?
