1 - 9 of 9 Posts
have an 03 2500 quad cab with a Probox installed under the back seats.
will this fit behind the back seat?
anyone have pics of their install that they would like to share?
'11 5.7L R/T Classic
That's sexy as hell.
If you've got the 60/40 bench, you'll need to measure the 60 portion from lower mounting bracket across to the other. Then see if your Zapco is less than that measurement. If it is, you can make it fit by remounting the amp over to that side. If it is longer than that, it wont fit back there easily. From that picture, I'd guess it will, but that doesn't look like a Ram's back seat. Here's a few pictures of mine. My amp's length is 25". If that's a Zapco DC1000.4, I think it lists the length at 24.4" so you'll be fine.
You'll need to arrange it between the two seat brackets, so you probably can't just slap that same board back there and have it work. Your seats wont be able to go all the way up, but as long as you mind the metal brackets, they wont damage your amp.
Upon closer inspection, that might be a DC650.6. If that's the case, it's the same 24.4" length, and you'll be fine.
yep, 650.6 (want to sell it but i'm toooo lazy, need more power)
24.4"L x 7.12"W x 2.35"H
do your amps mount to the wall or is there something to mount to?
Here's a link to another such recent request in the mobile audio section: http://www.dodgetalk.com/forums/showpost.php?p=2798086&postcount=25
I've got some more pictures of little things, and I'd be happy to go into detail on the build. I had to use trial and error quite a few times with mine and wasted 2 full sheets of MDF. If you get it right the first time, it's not so bad.
Zapco's aren't made for big boom, but the flexibility.....
i have never see a ram seat flip like that or seen a 03 quads floor like that
i see your wanting to do the same setup but behind ur ram seat sry bout that
Discussion Starter · #9 ·
i dont think that first pic is a ram
that setup was in my tahoe.
for now i installed two JL amps under the front seats.
thanks for the info!
1 - 9 of 9 Posts
