Neil I'm planning on making those changes in the future (heads, cam, intake mainfold,Tb,etc.). Right now I'm on a fact gathering mission. And I was going to get my PCM flashed by B&G. All those changes are no good unless the PCM is Programmed to maximize the new parts.Neil F. said:The commonly used part are Ford injectors. Unless you have some seriously heavy modifications, heads, cam, manifold etc, dropping higher flowing injectors will do noting but dump more fuel in and run pig rich. On that note dropping injectors in without a stand alone management system is not a good way to go.
TheBadazz said:I know I have 19lb/hr. injectors. I wanted to know what factory 24lb/hr injectors would be a direct fit for my truck.
