1 - 2 of 2 Posts
<<RamiNator>>
After checking with different people I learned that the ONLY way you can put 15" wheels on a 2000 Dodge is if the following.
If you have LESS than 1/2 inch between the brake caliper and the INSIDE of the wheel, you CANNOT put 15's on the truck.
If you have 1/2 inch or MORE, you can MOST OF THE TIME but NOT ALWAYS.
Was told that by tech at desertrat.com and 4Wheel Parts.com. Just a tid bit of info that I thought I would pass on.
grind the caliper down is the only way
1 - 2 of 2 Posts
