Hi all,
I'm having an electrical issue with my 05 Magnum RT, I found parasitic draw sourced to the ignition fuse. The car runs and drives fine but it's throwing all sorts of communication codes, 24 to be exact- ABS, Fuel/Oil, fan failures, TCM, the list goes on and I can't seem to trace out the source of the issue and like I said, it runs and drives fine. Grounds, fuses, relays all look to be good and working as it should.
The only tall tail sign of the issue is the chiming from the cluster and when I shut the ignition off the car sputters to a stall but the cluster shuts off immediately. Almost like the ECM isn't shutting down but it's just running out of fuel.
Any help or suggestions would be greatly appreciated 🙏
