1 - 10 of 10 Posts
******* Yankee
I think mine idols around 600 or so.
Mine was around 700-750.
grounded
mine is exactly 752 at idle wait.... 754 no........ 752 right about there on my scanner
sarge
i yell at microphones.
1000 since its been cold i suppose...after a moment and a little touch of gas itll drop a bit
******* SPACESTATION
thanks mines around 600 i guess thats normal
are you wanting to change the idle speed or just seeing if your truck's idle was with in the 'norms'?
edit: by the way, mine idles at 900 cold and 525 warm.
Discussion Starter · #9 ·
well i wanted to see what the norm was it usually stays around 500 to 600 cold or warm. i havent drove much for 5 months and im having trouble keeping it running..it will take about 10 turns to the key and finally it stays running
sounds like your IAC is dirty or inop.
Takes about 10 minutes to remove, clean, and re-install.
New IAC is around $50 i think.
1 - 10 of 10 Posts
