LOOK AT THIS HOPE IT HELPED
Symptom List:
P2302-IGNITION COIL NO.1 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2305-IGNITION COIL NO.2 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2308-IGNITION COIL NO.3 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2311-IGNITION COIL NO.4 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2314-IGNITION COIL NO.5 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2317-IGNITION COIL NO.6 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2320-IGNITION COIL NO.7 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
P2323-IGNITION COIL NO.8 SECONDARY CIRCUIT- INSUFFICIENT
IONIZATION
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P2302-IGNITION COIL NO.1
SECONDARY CIRCUIT- INSUFFICIENT IONIZATION.
When Monitored and Set Condition:
P2302-IGNITION COIL NO.1 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
When Monitored: Engine running and battery voltage greater than 10 volts.
Set Condition: If PCM detects that the secondary ignition burn time is incorrect, to short,
or not present, an error is detected. One Trip Fault. Three good trips to turn off the MIL.
P2305-IGNITION COIL NO.2 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
P2308-IGNITION COIL NO.3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
816
DRIVEABILITY - NGC
Symptom List:
IONIZATION
IONIZATION
IONIZATION
IONIZATION
IONIZATION
IONIZATION
IONIZATION
IONIZATION
816
DRIVEABILITY - NGC
