1 - 14 of 14 Posts
Well I took the battery of my 2003 Ram 1500 4.7 L truck and now my truck turns of on me when I am at a stop or slowing down. Instead of the motor maintain idle it shuts off. My warranty just expired. I called the dealer,they told me that I will have to place it on the computer and the cost is $75 and additional costs from there. It looks like i have to get ready for the shaft. :grum: HAs anyone had this problem? Or suggestions
:help:
So did you buy a new battery? I heard these trucks run like crap without a good battery, not like other vehicles that run okay once they get started and going.
KB
Did you try to remove the battery cable for 15-20 mins and then reconnect? It will reset the pcm.
Also, check and make sure there are no vacuum lines off. It will do the same thing.
KB
That is very true. On my old 99 5.2L Ram I had a bad
battery and needed to be jumped started. Once it
strated that lights would be very dim and strobe flash.
The truck barely ran. Once I installed the new battery
it ran like a champ.
How long has this been going on? My Jeep had a dead battery and had to be jumped. On the 30 mile commute home it ran like crap. Once I got home, shut it off and started it back up it was fine. My theory is that the computer had forgotten how to run the motor and took a bit of time to relearn it.
I had taken the battery off before, and the same misfire had happened but the computer adjusted itself and the truck ran perfect after using the truck for a couple of hours. Now the computer does not seem to adjust itself.
I will try using a battery of another truck to see if the battery might be the problem. I will also check for a loose vacuum line. Thanks Guys!!!!! :ylsuper:
C HEMI GO
Maybe I'm misreading. Are you trying to drive without a battery?
Discussion Starter · #10 ·
No, I placed my battery back on the truck and it was shutting off when i tried to stop or turn. I guess the computer was reset. I used the truck right now and it is running fine. I guess it took 3 days of driving for the computer to program itself. I am so relieved.
Drug Dealer
The same crazy $hit happened to me about a month ago. My battery died, I jumped it and drove to Autozone. I bought a new battery put it in, drove home and it died as I was pulling into the driveway. I started it back up and it was idleling erratically. I drove it for a couple of day and it never got better. It continued to die on me just like you're talking about. I took it to the dealership and left it with them. They replaced the Idle Air Control motor and it's pretty much fixed. If I'm sitting still and pump the gas a few times, sometimes it will start jumping from 400 to 1000 RPM's. The only way to stop it is to turn it off then back on.
I cleaned the throttle body and I'm about to put new pugs in to see if it helps any. I have no idea how one thing relates to the other but it did help. Maybe somehow it caused a short or something. Anyway the IAC motor was the solution to my problem. PLEASE let me know what you find out.
That story had everything....comedy, drama, mystery, suspense and a happy ending.
Discussion Starter · #14 ·
In my case the computer just needed to program itself. The truck is running like a champ, it has not turned off on me anymore. The truck idle works normal now. I am just glad that i did not have to take it to the dealer.:nutkick:
1 - 14 of 14 Posts
