1 - 20 of 28 Posts
Hopefully, you can pull out from your memory bank one of those rare and surprising solutions for a problem that is reported often but for which the proposed and obvious solutions are not working for me.
I have a 2005 Dodge Ram 1500 short bed, 2WD, with the 5-speed automatic transmission and 4.7 L engine. Purchased new, never damaged, maintained by the book. Runs as perfect as a truck can run except for the following problem.
— Humming-whining-whirring noise seemingly from the right front.
— The loudness and frequency increases with vehicle speed.
— When I unload the right side by taking a right-hand turn, the noise goes away.
— If I load the right side by taking a left-hand turn, noise volume and character do not change.
— If I coast in neutral, there is no change in the noise characteristics.
— if I change gears but keep the speed the same, there is no change in the noise characteristics.
— When I brake or accelerate, no change in the noise characteristics.
I have fifty years as a car enthusiast and Saturday mechanic, working on all my cars old and new, specialty and non-specialty, and I am stumped. I would appreciate your critical thinking on possible causes and how I would test for the cause. My truck is almost 18 years old and in near perfect condition and I want to drive it for ten more years, but the whining noise makes it sound like a schlock rod.
BACKGROUND
I have eliminated tire noise, improper wheel alignment, and worn wheel bearing. Here is the story.
1. I don’t know when the humming-whining-whirring noise started (hereafter let's call it the whining noise) because I ran a Gibson Super Truck muffler for many years and the muffler covered up any noises that might have developed either gradually or instantaneously.
2. The truck came with P245/70R17 tires. I installed much taller P255/75R17 M&S on the stock wheels during the time I had the Super Truck muffler installed.
3. When I removed the Super Truck muffler near the end of the service life of the tires, the whining noise was present.
4. I removed the worn tall tires and replaced them with similar tall tires (P255/75R17 M&S). The whining noise remained. I rotated the tires after 2,000 miles. The noise was still there.
5. I had the best and most experienced alignment expert in the city check and adjust the front-end alignment. He worked on it for two hours due to the fact he missed the front springs dropped 3/4 of an inch over time, and he had to redo the camber. He noted the whining noise and said to keep an eye on the right front wheel bearing, though he said there was no play in it.
6. I eventually replaced the right front wheel bearing with an OEM wheel bearing, because, well, it sounded just like wheel bearing noise. That was a waste of money as the whining remained.
7. When I unload the right side, there is zero tire noise from the tires. Truck is very quiet. So that eliminates tire noise.
Thanks for reading this far. Here are some unqualified guesses on my part: transmission output shaft bearing, drive shaft universal joint, wheel or suspension resonance set up due to tall tires, transmission.
Thanks for any suggestions you can offer.
Regards,
Lowboy
Wheel Automotive parking light Car Tire Automotive side marker light
Refresh my memory, are these regular wheel bearings (inner and outer bearings w/ races) or a sealed unitized hub? My 08s 4wd, never had to mess with front end. No change under acceleration or braking, ok. What about both at same time? I just did my front calipers at 185k due to a stuck puck on the right side (sounded just like a pad worn to the metal under braking) I can’t see your noise being in trans or driveline, I don’t think that’d be audible in one side vs the other.
· Premium Member
I have 46 years experience as a mechanic. Where I work they have a '17 Chevy 1500 4wd I'm having the same issue with. I replaced both from wheel hub bearings because like you said that's what it sounds like. The front tires are wearing very knotty and that was the next thing I was hoping would fix it. Now you've taken my hopes away, lol. I'll let you know if I find the issue with this truck and will be watching you to see if you find your issue. Sorry I was no help but going through it too.
Yes, the bearing are part of a heavy duty unitized assembly that bolts into place.
Discussion Starter · #9 ·
My truck does not have struts. It has conventional coil springs and shocks in the front.
I take that back. I am confusing my Ram with my 1966 Chevy Suburban. The Ram does have shocks inside the springs, but they do not look like conventional integrated struts. Sorry for the confusion.
Was gonna say, that’s 2nd gen stuff. I can’t see rotation/ speed making the strut talk, but if you’ve triple check everything else and still think it’s at that corner, you really only have so much left to check.
Discussion Starter · #11 ·
Yes, the most obvious fixes have been completed. I can't help but think that the biggest variable here is the over-sized tires. You can see from the photo they are quite large in diameter. They might be setting up a wheel/tire resonance because the stock wheel was not designed for that tall tire. Why only the right front? Maybe it is referred sound from both front wheels. Maybe the suspension at the right front has worn slightly different than the left front and is promoting the resonance.
Below is a screen capture of a description of wheel resonators. I vaguely remember reading about some Dodge truck wheels have resonators. Does anyone know if the Gen 3 stock wheels include wheel resonators? I have never seen the inside of my wheels.
I have been planning to install my stock spare tire at the right front to see if there is any difference and will report on that test when when I get around to completing it.
Finally, could it be a whining front universal joint referring sound to the right side a bit? When I stress and move the chassis/drive train components around by taking a corner, maybe that is sufficient to move the universal joint wear pattern to a new spot, stopping the whining.
__
Automotive tire Font Circle Automotive wheel system Screenshot
BACKGROUND
Regards,
Lowboy
I have learned over many years of working on these with that type of noise that you should also replace left wheel bearing. The noise will travel through suspension parts and frame. Went through the same thing many times. Hope you get it figured out
My opinion and only that is both front wheel bearings get replaced. Thinking that the noise travels and it could be the left, and also 50% of the parts today are junk so the new right bearing may be a loser. A strut rod that’s worn it’s biscuit could rub and make a noise.
Andygears
Having worked for Dodge and Chrysler for over 35 years, there are a couple of possibilities.
You say the noise changes with engine speed and left or right turning. There is a outside
possibility it could be related to the steering system. I have no idea of the mileage, but have
replaced steering racks and/or pumps for this exact complaint. Also might be the left side is bad.
Hand rotating a tire in the air, or checking for slack by hand is not always conclusive.
My last conclusion would be experience. If I had a dollar for every time I pulled a bad part
out of a new box, I could have retired 10 years sooner !!!!!!!
Good Luck, Daddyododge1
Discussion Starter · #17 ·
Thanks Waygust7. I have been considering referred noise, but not necessarily through frame and suspension. I will keep that suggested solution on my shortlist.
I would hate to spend another 400 dollars for installation of an OEM bearing only to find out that is not the solution. That would be 800 dollars in total. It does not seem like there is any easy way to test this outside of checking for play in the left side bearing. Is there a more conclusive test?
I will keep that solution on the short list as I drill down on all the suggestions. Thanks.
Lowboy
Discussion Starter · #18 ·
Andygears
Hi Andy, Thanks for those suggestions. I saw Waygust7's response first and it echoed your idea about replacing both bearings. See my response to him. Having two people suggest that brings it up higher on my consideration list. Anyway to test this hypothesis without spending another 400 dollars?
I will inspect the biscuit too.
Thanks,
Lowboy
Discussion Starter · #19 ·
Hi Daddyododge1,
Well you answered my questions about testing the left bearing. I can at least check for play in it. I might just have to take a chance and replace it if no other solutions work out.
Just for the record and technical accuracy, the whining changes with road speed. If I coast with engine idling, or if I down shift and keep the same road speed, the whining remains unchanged. I think that is what you intended to say.
The truck has just over 100,000 miles. It has never been worked. I get bread in it and take an occasional load of pruning branches to the dump.
The idea that it could be related to the power steering is interesting. For some unknown reason, I lost a power steering reservoir cap many years ago. Pretty sure I put it on correctly. The OEM replacement did not seem to be vented and pressure would build up. For example, if I removed the power steering reservoir cap after a drive, it would pop and release pressure when I removed the cap. I had to drill a small hole right through the cap to vent the reservoir properly. (At least I think I did the right thing. The reservoir should not build pressure, right?)
Is there a way to test the steering rack or power steering pump as the cause?
Thanks,
Lowboy
On my Dakota I had the same noise. Turned out to be the rear end. The rear end crapped out. The driver's side bearing that supports the differential in the axle housing went bad. Swapped the rear end out. Now no noise. Check it out. Won't cost you anything but some time. Check axle end play, check pinion shaft for side play at yoke as well as end play at yoke.
1 - 20 of 28 Posts
