1 - 6 of 6 Posts
ok i have a brand new viper 791 xv and a 2002 ram quadcab 5.9 , and no transponder key can someone get me an install diagram for the truck
i used to work in a small audio shop and then to circuit city's road shop no a defense contractor... thats besides the point ....ive installed a few of these including my avenger but i need the "cheater" sheet for my truck and info for the resistors and modules if necessary
Discussion Starter · #2 ·
bump id like to ge tit in this weekend
:D Hello!!!
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2002 / Remote Start
12volts pnk/blk & red/wht + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition blue (16 awg) + ignition harness
Second Ignition red or red/wht + ignition harness
Third Ignition N/A
Accessory green & orange + ignition harness
Second Accessory blue & blk/wht + ignition harness
Notes: These wires may not be necessary for remote start.
Keysense lt. blue - ignition harness
Power Lock white/green - driver kick panel
Notes: Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlock same wire as power lock
Lock Motor tan/pnk or tan/blk driver kick panel
Unlock Motor blue driver kick panel
Parking Lights+ black/yellow relay under hood at pwr ctr
Parking Lights- purple/yellow headlight switch
Notes: Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light purple/black + automatic day/night mirror
Door Trigger -
Notes: The LF door trigger is tan, and the LR door is tan/orange or purple/orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan/yellow. These wires are in the passenger kick panel. Use all wires and diode isolate each. See DirectFax document 1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm lt. green/orange - driver kick panel
Notes: This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock
Tachometer NOT green/orange ac ign coil, coil pack, or injector
Wait to start see notes
Notes: The 2002 Ram Diesel Pickups were carried over from the old body style. Refer to the 2001 Ram Pickup for wiring information.
Brake Wire white/tan + brake pedal switch
Parking Brake white/lt. green - parking brake switch
Horn Trigger black/red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
thank you
:D Hello!!!
Your Welcome!
ok these two connections where do i make them and do i change jumper settings ...its been a while since ive done this
other than that she works awesome
1 - 6 of 6 Posts
