I need help with swaybar Info!!
635 Views 2 Replies 2 Participants Last post by  DonG313
Hey guys well not long ago when I lifted my truck I came across the problem that when I turned "pretty hard" (not even full lock) my tires were pushing my sway bar end links into my spring for my suspension. I can flip the sway bar upside down and get long endlinks and I think it would work fine.. does anyone know where I could get something like this?
Or is there an aftermarket sway bar for a problem like this to help cure it?
Any and all information is appreciated guys!!
Will not having a sway bar cause my tires to wear faster? I sure as HELL dont need that happeneing!!
:help: :help:
1 - 3 of 3 Posts
Your tires wont wear any faster at all,and I have seen a company that makes different length sway bar end links,I just need to find it again.
I actually did some lite grinding on my spindles before I took my kit off and sold it, I didnt have any more issues once the small area was ground down some where the contact was made. This little ground area solved the whole problem.
Humm... I'll try that... will it not weaken the spindle any?
1 - 3 of 3 Posts
